Results 1 to 7 of 7
    Nov 2010
    New Jersey
    Combination boiler and water heater
    I live in Northern NJ and have a natural gas fired boiler (133 MBH) for HW baseboard heating and a storage tank for domestic HW. I'm interested in installing a tankless combination boiler and hot water heater that can provide HW for the baseboard heating as well as the domestic HW. Are there any manufacturers that make such products (2 1/2 bathroom home) for the US market? I've only seen Valiant and Worcestor Bosch for the UK markets.
    Mar 2001
    Lots out there.. your installer will be the key in this project. A combo unit may not supply the dhw you need... depending on your use habits.
    Nov 2010
    New Jersey
    what manufactures and models do you recommend?
    Apr 2010
    Red Deer, Alberta
    Quote Originally Posted by rmcassidy View Post
    Google "residential boiler" and you'll find many of them, most important is to get one that can be maintained by a local company, lots of heartache if you get an "orphan" system that local contractors can't service. In Canada, a good information source (general) is at http://oee.nrcan.gc.ca/residential/b...ers.cfm?attr=4 ...
    Oct 2009
    Los Angeles
    Boiler recs
    Recommendations at http://www.wholebuffalo.com/reviews/Boilers. Both gas boilers can be equipped to also provide domestic hot water.
    Jan 2002
    I've installed Laars Mascots and Triangle Tube Excellence units, but they are really better suited for 1 bath jobs like condo's, cottages.
    Is your current water storage tank an indirect or direct fired?
    Rochester NY
    Quote Originally Posted by hydronicsman View Post
    if you already have a nice indirect, might want to stick with that strategy.
    If it's just a crummy tank, Navien now makes a combi that supposedly is awesome, and really nicely priced.
    I'll be replacing my old Baxi with Navien soon, and will know more then. If you like using both showers at once there may be idiosyncrasies to get used to with a combi. By February, depending on your incoming temps, you may need to throttle back your hot supply valve (I have to do this with my Baxi, Navien does this automatically which is NICE!!). Or install low flow shower heads.
    Otherwise I'd be inclined toward the TT Excellence.
