Results 1 to 20 of 20
Thread: Furnace size required for 1100 sq ft house.
    Dec 2010
    Hello,
    I have a slight concern and would think this forum can answer my question since you all have a lot of experience with furnaces.
    My question is what size of furnace is required for a 1100 sq ft house with R12 walls (basement and upper level) and R40 in Attic it is a bungalow and the basement is completely finish with heating.
    Heating main level and basement, basement have cold air return vents and all rooms in main level.
    I am in the process of selecting a GMVC95 - 0704
    Hi-fire output: 67k Btu
    Lo-fire output: 47k Btu.
    This is a multi-position, two-stage, Variable speed gas furnace.
    What do you think?
    Any help, comments would be appreciated.
    richard
    Jun 2009
    Albuquerque NM
    Quote Originally Posted by netminder View Post
    Hello,
    What do you think?
    richard
    You need a Manual J heat loss calculation to determine the best size for your house. Most likely a 95% 70k BTUH is oversized for your house.
    The smaller GMVC95045 would probably do it but you need the calculation to know.
    Mar 2006
    The South
    I would suspect grossly oversized!
    Jun 2009
    Albuquerque NM
    Quote Originally Posted by tigerdunes View Post
    You're probably right. I have a tendency for understatement at times.
    Nov 2010
    Kansas
    Where do you live as that affects the load on the house.
    The statement below is my signature and just my overall feeling towards our industry and does not necessarily pertain to you nor this thread.
    There really isn't a legitimate excuse for not doing the job correctly!
    Dec 2010
    I live in Winnipeg gets pretty cold in the winter -29 deg C to -36 deg C.
    I keep temperature around 20 deg C at home
    Jun 2009
    Albuquerque NM
    It could be worse. You could be in Yellowknife or Whitehorse.
    Nov 2010
    Kansas
    All houses are different and to know for sure, someone needs to do a load calc on your house to tell you what size you need...other wise it is all a guess and ball park.
    Jun 2009
    Albuquerque NM
    Seriuosly netminder - if you want good comfort you need to get someone to do the calculation, or with a little effort you can do it yourself for $49.
    http://www.hvaccomputer.com/
    Dec 2010
    thank you garya505 for that link I will try that and see what I get. But just as an estimate if anyone lives in the same temperature and approximate square footage of house I am curious what is their furnace size. I know insulation values and windows etc affects but just looking for a ball park.
    Dec 2010
    O.k I had a tech come in and said that around this area 46~70btu is what everyone has due to the cold temps but he did say that the furnace blower maybe set to high.
    It cycles on low at start up (temp around 65deg-f) and then kicks in to high till it reaches the temperature of 70deg-f, then switches to low then shuts off (this takes about 15 min). Stays off for 7 min then back on again but on low this time for another 7 min this continues through out the whole day.
    What do you think is causing this or is this normal??
    Dec 2010
    On a Peninsula in NE NC
    sounds like you need to find where your heat is escaping
    Jun 2009
    Albuquerque NM
    Your indoor temperature is going between 65F and 70F? Is that what you want? Is your thermostat controlling that?
  14. #14
    Dec 2010
    No the temperature don't change from 65 to 70 and back to 65 again.
    What I meant is if the current temperature in the house is 65 and I set the furnace to 70 then it starts on low for a minute then goes to high (like a hurricane blower very powerful) for 15 min then shuts off.
    It will start back again in 5~7min to main the 70 but it only lasts for 7 min then shuts off again. I am not sure if this is normal but I would except the furnace to stay on all the time instead of cycling. Don't get me wrong I get enough heat in the house just worried about what effect the cycling is having on the house and furnace.
    Thanks for you replies, but I know you all have come across this before just wanted some clarifications.
  15. #15
    Jun 2009
    Albuquerque NM
    The furnace is always going to cycle, and would only run all the time if it was really cold outside. Sounds like you are getting 5 cycles per hour, which is a common setting for thermostats.
  16. #16
    Mar 2006
    The South
    netminder
    how many cycles/hr do you get?
    one cycle is defined as a run time and an off time for average winter low temp.
    post back.
  17. #17
    What is the temp outside when it does this kind of cycling.
  18. #18
    Dec 2010
    I am going today and check how much cycles I am getting per hour, I will also give check the outside temperature and post the results later on.
    In the mean time I have another question I am pondering, if the blower fan is to powerful can it harm the house? How can a house become over pressurized? My blower fan goes on like a hurricane blowing my curtains all over the place, I don't mind the noise except that it is powerful.
    Is there a problem with this.
  19. #19
    Mar 2006
    The South
    netminder
    if your new furnace is sized correctly, you have adequate ductwork both supply and return, blower motor is VS and settings are correct, then blower motor should barely be heard if at all.
    IMO
  20. #20
    Rochester NY
    gmvc 70 drops to 45, so if sized correctly you should get nice long run times with a properly set up 2 stage stat, or better yet the communicating stat. That seems a lot of furnace for 1100 sf, even in the great white north.
    As you can see, airflow noise complaints raise antennas here. Hopefully your ductwork can efficiently handle the airflow needed for a 70. If not, tightening the house and getting a smaller furnace will really pay over replacing ductwork.
    A thorough audit should tell your current load and determine if there are opportunities to tighten up and downsize your furnace. IMO, you REALLY need a blower door test number with temperatures that cold for an accurate load calc. Goodman might not be the ideal brand if you can't get your load to 45 as that house may straddle the range between the sizes. Others, (like carrier) will have broader output range (mvc060 = 22k through 58k)
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
