Results 1 to 4 of 4
    Question
    Hello, I just installed a Honeywell vision Pro 8000 (TH8320) on a heat pump system. The thermostat is working great, the problem is that it does not let me comfigure from setup option 0300 and up in the installer programming. I mean from setup option 0290 it jumps directly to Test 1 instead of letting me configure the other options.
    Any ideas why this could be happening?
    Thank you in advance,
    Sincerely,
    Luis C.
    do you have the correct option chosen in #290 ???????
    Right, in 290, select option 2 to keep going.
    Fort Worth, TX
    Installation instructions, anyone?
    Every VisionPro I've ever bought has a set.
    Building Physics Rule #2:
    Building Physics Rule #3:
