Results 14 to 19 of 19
Thread: R-G fan drive
    my precious humidifaction i'll die without you...
    Have you purchased your steam humidifier yet?
    I know EWC's Autoflow brand steam humidifiers will turn the system fan on themselves when himidification is needed, and isolate the call to the G terminal of the equipment from G on the thermostat.
    They also give instructions for how to set up a fan failure safety lockout.
    http://www.ewccontrols.com/steam_humidifier.htm
    west chester pa
    Originally posted by producteng
    I'm not interested in discussing the pros and cons of humidification, which is why I specifically left that out of my first post. What I AM interested in is what happens when you put a second set of contacts in parallel across R & G, which is exactly what I DID ask in my first post.
    Thanks anyway.
    I'm an idiot and need your help, But I also want to be a smart a$$ with reply's like above. Take a jumper from R-C if you see a spark it will work fine..
    Lancaster PA
    Yes you'll back feed the Y terminal to the outdoor unit.
    Check the vision pro stat, the 1 model has fan recycle ability, and may be just what you want.
    24 volts at humidastat,which energizes coil and closes to sets of contacts,one set is humidafier and the other set is 24 volt to g terminal in airhandler,,,,,,,,,will it work?
    nevermind!!
