Results 1 to 13 of 19
Thread: york
    Feb 2005
    Hmm
    anyone install the new affinity R410A heat pump would like to know any details about service or installation experiencesyou had.... thanks
    Feb 2005
    Installed and removed, was a nightmare and they could not fix it.
    Probably not installed right. York requires dealer training to install all 410A products.
    Kansas City
    You mean you couldn't fix it?
    What kind of problems did you have with it? Would like to know more about the issues you saw.
    what color was it?
    i've been hearing of troubles with the "bermudas" and "chocolates"
    Feb 2005
    The unit was installed for a department of the government that will only accept ozone compliant refrigerants, the unit was put on a roof with the air handler five feet below the unit it lost three compressors in six weeks and I did not do a service call on it York came out each time and said that I could not use the ceiling space as a return air plenum. that that was the cause of the problem and said that they will not put another compressor in it unless we resolved that problem. In our discussion i mentioned that the unit we took out was running fine and had for ten years in the same condition, he obviously couldn't put his finger on it so he fed me a bunch of fairy tales. This agency of the government will no longer accept a bid with York equipment on it in this region.
    Central Kentucky
    Originally posted by billva
    what color was it?
    That is hilarious.
    Smile
    For a simple panel change it makes a nice up sell! All though that comment was funny.......
    what color was it?
    Hey fatty....Almost every compressor failure points to some type of installation or application error. I have replaced countless compressors and never had to replace one a second time. Most failures were a result of environmental, or application issues. Given the complexity of 410A and POE oils several installation and service gudelines MUST be followed or there will be a failure. R22 and mineral oil are very forgiving but 410A and POE oil is not. If I had to bet on it there was moisture in the system because of poor practices. I have worked with York equipment a long time and have found it to be less prone to service bulletens and recalls.
    west chester pa
    bet the lineset was to short had a carrier 410-a unit same thing rep never looked at the linset. paid for us to install anew unit installer noticed line set was 10 ft extended haven't been back that was 2 yrs ago
    Feb 2005
    Are you serious about the lineset ? We don't actually install the stuff we sub it to some pretty good contractors, we also will not service the unit until it is out of warranty. The line set was amazingly short like I said it was about 5 feet away and thats at most.
    Kansas City
    Why would anybody use the ceiling space for return air? Nothing like sucking in 100* air. Also did you make sure everything in the ceiling was plenum rated? I think the York tech's were right, high pressure's - high superheat = bad compressor.
