Problem with lighting natural gas fireplace
    Hello
    I've got a Majestic HE25RN natural gas insert which recently started having a problem. The pilot light stays lit but when I turn on the switch to produce flame nothing happens. The switch contact is OK.
    Any idea/suggestions on what is causing this problem??
    Dec 2003
    south NJ shore area
    fireplace
    try to turn the gas valve to the on posistion.
    GOOD WORK IS NOT CHEAP! AND CHEAP WORK IS NOT GOOD!
    IF YOU THINK A GOOD HVAC COMPANY IS EXPENSIVE. THEN YOU SHOULD TRY A BAD ONE.
    what kind of switch is it ,jump the switch.
    Rauchen, the millivolt reading at the gas valve needs to be at minimum 300 m.v. to actuate gas valve. Im assumming this is a millivolt system? If you find a lower reading than 300 m.v. check pilot and or pilot generator and clean or replace as neccessary.
    New Hampshire
    When this happens the pilot is usually strong enough to keep the pilot energized but if the pilot is a little dirty the millivoltage is not enough to energize the main valve. There is a voltage drop in the wire to the switch and back again.
    We are talking millivolts here.
    You can post this on the "fireplaces section" too for more replies.
Comfortech Show Promo Image
Comfortech365 Virtual Event
