Results 14 to 20 of 20
    bryan l Guest
    Okay I am a fridge guy and dont do any build automation but if you want cheap, reliable and easy, could you not just use a Belimo damper motor and a floating point controler, or a 2-10vdc,0-10vdc, 2-20mA space temp controler?
    Very cheap, Very tough and low tech.
    Just a thought, but I might be WAY off. What do I know about Chilled water? Not much I could freeze it for you
    Columbus Ohio
    Yes Bryan ...exactly, actually this TBS/Baysys ZN1063 is 4
    to 20ma and the actuator is Honeywell but just like a belimo, Its cheap and simple. Pretty good stuff I hear
    Jul 2002
    Where are you guys looking up this stuff?
    Jul 2001
    Canada
    http://www.tcsbasys.comclick on products link
    [Edited by Control Man on 02-18-2005 at 01:27 PM]
    Feb 2005
    Do you have a link to the price list?
    Feb 2005
    Ive worked on quite a few different systems, There are loads of stand alone controllers you could use, designed for 'fan coil's'. I recently fitted a siemens controller for about 120.00, it uses wax valves and phase cut control. There are loads of 'signal converters' on the market for under 100 if you want to use existing valve actuators.
    Another option is the 'electro-controls' PI-controllers. Nothing fancy but have found them to be relyable, you will need a small panel to house the pcb,s in though. They offer vast range of sensors and outputs to suit your need and are very resonable. An optimiser or other stand alone controler would probably cost in the region of 700 but I wouldnt think you would need it on a fan coil unit. Good Luck
    I would use the honeywell t775 with the modulating output it is easy to program and very reliable. I have installed several of the t7350 thermostat but not used the modulating output yet. I like those very well also. very cost effective.
