Results 1 to 13 of 14
Thread: great stuff
    Jan 2003
    You know. That "great stuff" that comes in a can at Home Depot. It foams up and takes what ever shapes.
    Question: How come they don't use that for insulation? Like pump it into and behind drywall or even attics? I would rather mess with that than fiberglass.
    Maryland's Eastern Shore
    They do, its just more expensive, because wiring "has" to be done in conduit, boxes need to be sealed, and the product is just more expensive...
    Sep 2003
    western canada
    Money talks. Seen something similar on commercial aps. for sound proofing.
    work to live not live to work
    Cincinnati
    I've seen them use it in high end new construction. Imagine trying to run a new circuit down an exterior wall a few years down the road.
    Hence, the need to run wiring in conduit...
    Cincinnati
    Well of course. But I mean a new "after thought" circuit. You could use Romex and still insulate it with this stuff. But later on if you wanted to add a circuit? Wouldn't it be a pita to do??
    Why would you have to use conduit? Personally I would prefer it but I've seen Romex used with this stuff.
    Jan 2003
    Thanks for the response.
    How much more expensive? Where can I get some? I don't want to buy a bunch of cans.
    Cincinnati
    This is what it is. Do a Google search or check the local box stores for kits. "polyurethane foam insulation"
    Hell Hole Swamp
    Works great for duct insulation also.....
    [img]http://groups.msn.com/_Secure/0aAAjA*kcPdGbIigESxQuFlmB17IQxnOJjoFLKhOshgvgtLEKZ kiLg8LceshCxI7oxEYPqxJysjBZCct9gSuIO0ptfpeVBiAUMRZ n5E36XjJ6l9ucnx!Q8L0lnRYo3GHfPAjn0yzHDVwd8ZpkeJdu7 2xsYS80LjAg/PICT0145.jpg?dc=4675497330467071308[/img]
    Do you do that all the time?
    Hell Hole Swamp
    I aint claimin that one....leeched it from the wall of shame
    Deos it cost much more that way?
