Results 14 to 15 of 15
    "are you sure about the labor allowance"
    Labor allowance is for the quality pledge.Which is for heat exchanger or compressor failure in the first five years.Blower motors don't apply.If it is the motor you should NOT be charged for the part.
    Nov 2001
    On the t-stat, switch the fan from auto to On,
    If the motor runs then it's probably the control brd.
    If it doesn't then it could be the capacitor or motor.
    not every filter needs changed every month.
    Depends on the living habits of the h/o'er.
    But I have also seen the ones that once a month wasn't enough. I'm sure alot of you have seen those places.
    Which have you done ?
