Results 1 to 13 of 15
    I have a question, can a 3 year old furnace have a bad blower motor? the diognostic light on my furnace is blinking once and the legend says thats a limit switch open or load on w. (a tech wants to put in a motor)
    SE Michigan
    Does the blower operate? or does the furnace cycle off on limit?
    In addition, those furnaces have an 8 year parts warranty and up to a 250.00 dollar labor allowance. As long as the trouble was not caused by an air restriction.
    [Edited by coolwhip on 02-10-2005 at 03:28 PM]
    nordyne 80+
    it cycles off and no air comes from the vents.
    to coolwhip
    it cyles off & no air comes from the vents.
    SE Michigan
    Could be a bad motor or relay. Its hard to tell from here though. When was the last time you changed the filter in those three years?
    in november, are you sure about the labor allowance
    I would check the voltage at the output on the control board, if that checks out I would ohm the motor windings. It could be a bad cap to, that should be tested also. Sounds like you have a parts changer to me. Good luck,
    Brian
    chicago suburbs
    november???? change your filter every month if it is 1"
    FILL OUT YOUR PROFILE!!
    MODEL#
    seriel#
    please
    model#g6rkseries 80+ high eff. downflow ser.#g6a010203043
    southern illinois
    depends alot on size of duct too......that mod# is off a little....it should say tonnage of blower and btu....
    southern illinois
    i would inspect the a-coil and inside of duct too.....tell him you want to know what the static pressure readings are...ask him to try and figure out why it failed.
    southern illinois
    and these blowers aren't bad to replace.......i like em cause you don't have to remove control board,t-former,etc.
