Results 1 to 2 of 2
    Got this a little late and homeowners may not need to worry about this cause it was mostly used in commercial work. But putting here for info only.Please read
    That is the problem with laying off old designers -- the mfgr keeps repeating the same hazards --
    Because of lots of fires in the first color TV sets, Bussmann developed the thermal fuse ~1965 -- those TVs had lots of vacuum tubes --
    I reworked the back of my set to have only vent slots at the top, pasted alum foil over 80% of holes on back Masonite cover, which gave a chimmey effect = tube burn out reduction by $15 each month.
    You all don't remember seeing tube test machines in all electronic distributor shops -- saw one the other day in a musical instrument store --
