I have a cold room at 40F and 40% RH. Below is a carpenter shop with 70F and 50%RH.
The slab is 12" thick. Do you know how to calculate the wall temperature below slab in the carpenter shop? I want to check if it is lower then the DP in the carpenter shop, and calculate the insulation if necessary.
