Results 1 to 8 of 8
    Williamsburg, VA
    What's the principal behind a variable speed air handler and why is it better than a single speed A/H?
    Jul 2002
    Zelienople, Pa
    Uses less power
    Removes more humidity
    more even temps
    quiet
    24/7 air filtration
    With your 16i it is required...
    Williamsburg, VA
    Does this mean less dust too? That was a real problem with the old single-speed unit. Of course now I have the Honeywell F200 as well so that should help.
    Jul 2002
    Zelienople, Pa
    If they have the dip switches set to Comfort R and you leave the fan in the "on" position...
    Check that filter every month or 2 to see how it loads up.
    Williamsburg, VA
    If they have the dip switches set to Comfort R and you leave the fan in the "on" position...[/B]
    Not sure. I need to check.
    4H: Hot, Humid Houston H.O.
    Fan on
    As I understand it, if you leave the fan on all the time during the cooling season, you *will* increase humidity in the house. Independent of whether you have the Comfort-R settings (I would consider it an mistake if they did not set up Comfort-R).
    Not sure whether that will be a problem in your climate.
    Best of luck -- P.Student
    You can get a slight increase in humidity after the outdoor unit shuts down, but its not going to jump 10% because you have the fan running 24/7.
    daytona florida
    as long as your system is charged with the proper super heat and sub-cooling you should not have any problem with any humidity, blower on or off in comfort r
