Lennox condensor model: hs16-511u-5p serial: 5187e14990 Can anyone tell me how many tons of cooling this condensor is? Thank you in advance.
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.
4 ton single phase. Solid unit, heavy too. The only real issue with them is that the coil never looks dirty from outside. You have to take the top of of it to inspect and clean the coil.
RSES Certificate Member RSES-SWRA President The planet is fine, the people are ! -George Carlin
2 ton - 261 - 024 21/2 ton - 311 - 030 3 ton - 411 - 036 31/2 ton - 461 - 042 4 ton - 511 - 048 5 ton - 651 - 060
If you try to fail, and succeed. Which have you done ?
Forum Rules
