Results 1 to 6 of 6
    I'm looking for a simple method to size for hydronic heaters. How many CFM/BTU to keep an X sized space at X degrees.
    Cincinnati
    You put the biggestest one in that will fit.
    Colorado flatland native
    Simple answer.
    It's not that simple.
    or...
    It depends
    ask on "the wall" at http://www.heatinghelp.com it's the hydronics site from the god of HH2O
    Walter Matthau
    well, you could use a rule of thumb such as: 1.5 cfm per every square foot of office space. this will not only take care of your heatload, but will address your fresh air requirements. now convert this to 400 cfm per ton. then, for each ton, figure about 25000 btu. this converted to baseboard @500 btu per foot using 180 degree water will require 50 feet of baseboard. this formula sucks so dont use it in real life, just do a load calc!
    There is a lot truth to that around my neck of the woods. We have a lot of people who do hot water heat but do not do furnaces or air conditiioning. (thank goodness)
    Oil hot water boilers are the "King" "Boiler won't keep up- put in a bigger nozzel." Of course if the boiler is oversized for the job then you are golden.
    Sep 2001
    East Stroudsburg, PA
    I have competitors ho do that, then a year or to down the road, after a hundred hours or so of impingement, I get to replace the boiler.
    I LOVE it when they overfire them.
