Results 1 to 8 of 8
    May 2010
    Heat pump noise in winter
    My house uses a heat-pump for heating. In the heating mode the outside unit makes a lot more noise when compared to the cooling mode. Why is this? Does the compressor run faster? Or the cooling fan? Or both? Do I need to call a service pro, or is it normal?
    Sep 2006
    Leavenworth KS
    Hmm Service
    I think a service call might be wise. They should not make any more noise in the winter than in cooling mode.
    Mike
    Massachusetts
    Quote Originally Posted by timlein View Post
    "....more noise..." isn't particularly descriptive. Would that be a squeal, squeak, squawk, bang, boom, bop, scratch, clunk, gurgle, giggle, roar, rush, scream or some other noise???
    May 2010
    I'd say it's a low-frequency hum. May nothing changes for the heating mode, but the low temps outside effect performance/noise level of a bearing?
    Do you hear this sound coming in the house from the outdoor unit? If so, pretty typical.
    May 2010
    Yes, I hear the noise inside, but it's coming from the outside unit. In cooling mode, though, the noise is a lot less. Normal or not normal?
    Oct 2002
    In the heat pump mode the hot high pressure refrigerant is being pumped diectly into the home via the larger insulated refrigerant pipe. That pipe needs to be isolated very well at each hanger strap and not clamped tight to the floor joists as you WILL get compressor hum sound transfer into the home. In the cooling mode the hot gas refrigerant coming directly out of the compressor goes through all the outdoor condenser coils which acts as a muffler prior to any refrigerant going into the home via the smaller copper tube which is usually not clamped tight to the floor joist hence the quieter cooling cycle operation. Hope that helps.
    May 2010
    Quote Originally Posted by ghunsicker View Post
    Yes, that has to be it. You can put your hand on the inside wall( it's a townhouse on a concrete slab) and feel the vibration as well as just hearing it. Causes bass standing waves in the room! Doesn't sound like an easy fix: I'd need to cut drywall to install some good elastomer/isolation mounts for the pipe. I may, as a start, try to install some better mounts on the compressor. May not help much, though. We shall see.
