Thread: Totally New HVAC System
01-31-2005, 09:19 PM #1
- Jan 2005
- 2
I have 2 proposals that I am considering for a completely new HVAC install for a home that is approximately 4000 sq ft. I want to do it right. I have a lot of respect for the postings I've read over the last month, and I appreciate any time you have to comment on the proposed systems. The following are the comparisons:
Basement and 1st floor (floor registers on 1st floor):
Trane TUX080, 92%, 80,000 BTU or Bryant 315AAV048090
+80V Evolution,88k BTU
Trane 2TTR2030 2.5 ton 12 SEER or Bryant 533GNX024 Puron
12-14 Seer, mtchng coil
Trane TXC030 cased evap coil
April Air digital prog thermo or Evolution control panel
April Air 600 humidfr or Bryant HUMSBP humidifr
Honeywell F300 air clnr and Single bulb germ uv lmp w/Bryant
2nd and 3rd floors (ceiling ducting 2nd and 3rd floors):
Trane TUY080R9V5, 92%,80kBTU, or Bryant 94.1 Evolution
2-stage, variable 355MAV060100, 100kBTU
Trane 2TTR2042 3.5 ton 12 Seer or Bryant 598BNX048 2/4
ton 16.5 Seer,2 speed
24k/48kBTUs Puron
Trane TXC042 cased evap coil or Bryant factory coil
2 April Air digital thermos or Evolution controlpanel
1 Perfect temp 2-zone systm or Evolution 2 zone systm
April Air 600 humidifier or Bryant HUMLBP humidfr
Honeywell F300 air cleaner and Single bulb germ uv lmp w/Bryant
01-31-2005, 09:24 PM #2
- Feb 2004
- cocoa fl
- 143
look at carrier puron infinity or their higher eff systems the infinity is i believe the best system on the market. just go with the contractor you feel most comfortable not just the best price.. but from what systems you are looking at i think you are not just looking at the price but also quality of the system and contractor which in the end will make you and you're family very comfortable.
01-31-2005, 09:32 PM #3
- Jan 2005
- 2
Thank you, Matt. I will look into the Infinity.
06-30-2006, 03:49 PM #4
- Jun 2006
- 2
Has anybody given you a heat load on your proj.
