Results 1 to 10 of 10
    Apr 2006
    mechanical room
    some pics. of some equip. we take care of
    check it out
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	141601   Click image for larger version.
ID:	141621   Click image for larger version.
ID:	141631   Click image for larger version.
ID:	141641   Click image for larger version.
    May 2002
    Baton Rouge, Louisiana
    The Trane chiller has been or currently is being washed with condenser coil cleaner?
    Dad's Hideout The online mancave for dads
    Oct 2001
    right on that one........ a couple of plastic garbage bags would do wonders for those compressors in the long run and if that unit is 460V little acis on the windings in the fall let it sit with the snow melting till spring and baaaaaaboom
    "when in doubt...jump it out" http://www.youtube.com/watch?v=aMy-sAHwS4E
    we got one of dem choo choos with dual circuits, one circuit having a bad evap. it may be going away this spring. 350 tonner.
    Jun 2010
    U.A. (upper Alabama)
    Is that liquid receivers in the second picture?
    Apr 2006
    mechanical room
    no, oil separator and it's scale on the compressors from spraying the coils with water when some fan motors went out over the summer, not our idea and we strongly recommended not to do it but it's the cust. machine not ours and they are paying the bills soo
    Dec 2003
    Half way between North pole and Equator
    On the third pic, is that chiller down in a hole? Looks like a good opportunity for recirc of cond air.
    Hows your head pressure in the summer?
    “If your work speaks for itself, don't interrupt.” ~Henry J. Kaiser
    Apr 2006
    mechanical room
    nice call, r134 runnin 270, we've gone thru like 6 motors this summer and on a good summer day, you can walk by the side the walls on and measure close to 140*f
    Apr 2006
    mechanical room
    some more pics.
    hh
ID:	141821   Click image for larger version.
ID:	141831   Click image for larger version.
ID:	141841   Click image for larger version.
ID:	141851   Click image for larger version.
    Apr 2008
    Pa.
    awesome pics. I do residential and light commercial. I really wanna get into and learn commercial and industrial stuff someday.
