Thread: DC motor
01-31-2005, 08:24 AM #1
- Oct 2004
- 40
I've been looking at furnaces and I see some have DC motors. Is there anything different that needs to be done when installing the electric to the furnace? Is there some sort of converter required?
01-31-2005, 08:33 AM #2
No, there is nothing different about the supply voltage. There are set up switches in the furnace which must be set though. The dc motor is a variable speed motor and uses far less electricity to operate. It is a good motor to run constantly to eliminate stratofication.
01-31-2005, 07:56 PM #3
- Nov 2004
- Naples, Fla.
- 1,403
The DC mtr you're refering to goes by several differnt names, ECM (electronicly communtated motor), varible is probably the most often employed. This is excellent technology & I highly recomend it.... but get the extended warranty, you won't believe the replacement cost.
