Results 1 to 13 of 16
    Dec 2010
    Best way to save money on HVACR energy usage?
    I am looking for opinions or ideas on the best way to save money on energy bills, not including the usual set backs, routine maintenance, or purchasing of a higher efficiency unit. (ex. programming thermostats, HVAC/R control upgrades, etc.)
    On any application, but an emphasis on systems that use compressors for cooling (Chillers, Refrigeration) or any heating.
    Thank You, This is sincerely appreciated.
    P.S. I have been looking into demand response controllers, thermostat dead-ban adjustments, or anything else to help. Its expensive to cool large spaces!
    Dec 2009
    New Hampshire
    Do you have an economizer? This will allow you to draw in outside air on days where you need cooling inside and the outside air temperature is lower. Also have your equipment serviced regularily to make sure you are operating at peak performance.
    Somewhere in the world.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Mar 2010
    Va.
    If you have cooling towers you can install "plate & frame" heat exchangers for free cooling.
    bouncer, I like your signature
    look for ways to turn your system OFF...it is the most efficient way there is!
    things like an economizer, wider deadbands (sorta), dry coolers (if conditions exist), etc. make a big difference.
    Mar 2010
    Va.
    I've never heard the term-dry cooler. Can anyone exlpane. Is it something used in colder climates.
    Mount Airy, MD
    Quote Originally Posted by PSUMAN View Post
    Contact a local Controls Company in you're area to discuss, you would be pleasantly surprised as to just how much we can save using various controls strategies with pay backs in as little as a month.
    Jul 2001
    Canada
    PHISHER
    Here is the basics for a quick comparison
    Wet cooling towers or simply cooling towers operate on the principle of evaporation. The working fluid and the evaporated fluid (usually H2O) are one and the same.
    Dry coolers operate by heat transfer through a surface that separates the working fluid from ambient air, such as in a heat exchanger, utilizing convective heat transfer. They do not use evaporation.
    Fluid coolers are hybrids that pass the working fluid through a tube bundle, upon which clean water is sprayed and a fan-induced draft applied. The resulting heat transfer performance is much closer to that of a wet cooling tower, with the advantage provided by a dry cooler of protecting the working fluid from environmental exposure.
    Mar 2010
    Va.
    guess I should have known that. In all my years in the field I've never heard them refered to as wet or dry though.
    Hampton Roads, Virginia
    I hate to say this being in the controls business, but most people are better off spending the money on improving the energy efficiency of the building itself, i.e. insulation, doors, windows etc. Only once these items are doing a good job should equipment efficiency or control schemes be considered.
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    1. Improve the structure. Otherwise, you are "closing the barn door after the horse has bolted".
    2. Install controls that can be locked to prevent changes by tenants. Said controls should not display the space temperature.
    3. Put energy saving heating and cooling setpoints in the controls. Heating no higher than 68F, cooling no lower than 75F.
    3. Zones/areas that border each other should have identical setpoints, to avoid the zones fighting one another.
    4. Actually lock the controls once the setpoints are entered.
    5. Put one person in charge of temperature monitoring and maintenance, with an alternate for times when that person is not available. Those persons must have the ability to politely but firmly decline to change setpoints to satisfy individual tenants.
    6. Perform air balance as needed to eliminate trouble areas. It shouldn't be necessary to have a setpoint of 72F in order to maintain one office at 75F.
    7. Make server rooms and other areas that have a high concentration of heat producing equipment their own zones. This may require dedicated equipment. It shouldn't be necessary to run the chiller to cool one room. Keep the doors to this room shut.
    It seems to me that the key to successful energy savings is the on-site manager. I work at facilities where the setpoints are constantly changing because the manager or owner respond to every little demand from the tenants, and it seems that caving to every demand just produces more demands. I work at other facilities that have energy saving settings and I marvel at the lack of service requests. It is a marvelous thing to go into a facility and see every zone maintaining setpoint within one degree, and those setpoints are much more energy-saving than other facilities, and have the property manager say there are no issues.
    Where's the difference? Not the tenants, people are the same. But people will adjust. When management says a policy of energy efficiency is being implemented, there will be complaints. There will always be complaints. But once tenants and occupants come to understand there is no variance, they will adjust. But a key is making sure everyone is in the same boat. You can't have the entire office be 75F except for one office that's 80F.
    I'll shut up now. This happened to hit one of my hot buttons.
    Australia
    Quote Originally Posted by klrogers View Post
    Kevin
    Thank god someone else said it!
    Blinds for windows aren't expensive, and I've been suprised at the difference they can make when it comes to hot days/large windows.
    Definately lock-out the tenants ability to adjust things if you can, or restrict them to min/max setpoint positions. The more you react, the more people complain (within reason). If they produce a $2 thermometer, then thump them over the head with it. Politely.
    Use 1 calibrated temp meter (yours) only on site. If the trades keep passing the blame between them then get them both there @ same time.
    Make sure you don't have one 'rogue' zone causing 80% of the energy problems, there's usually one area that was remodeled (ie walls removed) and now spends its time fighting the one next to it.
    Check that sensors that are physically located on perimeter walls don't have a great hole where the cable enters thru the wall. Hot/cold air comes thru, this one can cause BIG problems depending on the building. The sensors are best 'insulated' from the surfaces they are on. The back of Siemens L-Types are a good example of this.
    If thinking about maintenance contract watch out for the number of maintenence hours controls companies will try to sell you, the techs GENERALLY don't bull**** you as much as the managers/sales guys. Don't allow yourself to be impressed by the capabilities of the graphics. 99% of your time will be checking values, and adding/adjusting schedules.
    Get one of those trigger laser temperature meters, not cos they're good meters, but if you carry it in a hip holster you can pull it out like clint eastwood and read the temperature of the wall 30 meters away, then spin it around like a 6 gun and holster it. I mean, who wouldn't give THAT guy money? If you get 2 of them, no-one will ever argue with you again, not even the power company.
    The DDC system... guilty until proven innocent
Tags for this Thread
