    Jan 2005
    What experience does anyone have with the loop by pas hepa filters that are added to the return air ducts?
    Apr 2004
    where you at?
    what about the remaining 75% air volume that does not by-pass?
    too expensive - both purchase and maintenance (HEPA replacement, power draw, ext.), with little gained.
    Apr 2002
    Seen the fan powered ones where they draw air 'upstream' from return duct, filter it and blow it back 'downstream' into the return duct closer to the furnace/air handler. They even come with VS motors.
    Expensive, but with the fact that HEPA filters are restrictive to start with and could have a change out pressure drop as high as several inches, the bypass would be the way to go if you wanted that level of filtration.
    If it was like a blind pepsi taste test, I don't think the most hypochondriac (sp?) HO could tell the difference between a HEPA system or a good media air cleaner.
    http://www.ductstrap.com/
