Results 1 to 12 of 12
    Nov 2002
    NJ - WORK IN NYC AREA
    OLD CARRIER COND LOW AMBIENT NEEDED
    Have an old Carrier Condensing unit. Our rep. says they don't make a low ambient kit for it?? Hard to beleive. Any of you old time carrier guys can assist??
    M# 38E012500 SER# P15833 208 3 PH Has two 1PH motors.
    I know I can rig some thing but would like to go with motor master if possible. Would anyone know if it was used in this unit. Has original motors!!!!
    "My hands are for sale"
    butler pa
    cant you get a ball bearing motor and add the motormaster ?
    Dec 2006
    Middle Tennessee
    retro a new low ambient kit
    why do you need the old style?
    Dallas ,Texas
    I will check for you.
    UA 100
    It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
    Nov 2002
    Wink
    I was going to refit it but I did some checking on carrier site. Our rep told us its obsolete.
    I found unit on their site. Calls for a Motor master and fan Pressure switch on second fan. Also TD on LP control.
    I'll order parts in morning.
    Thank all you guys for your input!!
    Mr HVAC
    Oct 2009
    Atlanta,Ga.
    Carrier motor master works good,but expensive.Penn makes the P-66 pressure actuated fan control(I have used and like this control) ICM also makes a good control(ICM325hn) this is more of an eletronic control that senses liquid line temperature and adjusts fan speed.It is also good for sleeve and ball bearing motors.If money is the problem.you can use a fan cycle control.I don't care for them, they cause fluctuating pressures. Check local parts house,Motormaster is (as I think you know) sold at carrier dealer.
    Oct 2009
    Atlanta,Ga.
    ICM also makes a good pressure switch bypass delay on make timer for low ambient startup ICM part# ICM1758.Only about $20.00 and works good.
    Hampton Roads, Virginia
    P66 is on the way out, the replacement is the P266 I believe.
    Kevin
    "Profit is not the legitimate purpose of business. The legitimate purpose of business is to provide a product or service that people need and do it so well that it's profitable."
    James Rouse
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by klrogers View Post
    Kevin
    look at all options before forking out the cash for a p66
    especially for equipment so old, they don't even make parts for it anymore
    NW Arkansas
    Just get an ICM single phase head pressure controller for each motor unless you want to control one of the motors with a high pressure fan control. Just be sure to install the sensor in the correct part of the coil and do not attach it to the LL. All my air to air units run year round. I have had good luck with the ICM and the price is not too bad.
    Signature on hold. Trying to find a real Jefferson quote I like. Others here have bogus Jefferson quotes too.
    Nov 2002
    Thanks guys for all of your input. Will probably go with a motor master.
    Dallas ,Texas
    Quote Originally Posted by mrhvacmechanic View Post
    I like your way of thinking.
    UA 100
