Results 1 to 7 of 7
Thread: Proper Hard Duct sealing?
01-25-2005, 08:28 PM #1
- Nov 2004
- 5
My local inspector is doing some code research for me concerning required duct sealing options but since code is the minimum standard, I would like to know the best method(s) to ensure an air tight duct system. For instance, in an extended/graduated plenub comprised of hard round pipe, how should the connections be sealed? What about branch offs of flex? What about insulating options for round pipe? Note: this is a crawlspace installation.
01-25-2005, 09:42 PM #2
- Feb 2004
- Knox CO. KY Occupation: Residintial and Commercial instalation, service,and commercial refrigeration. Interests:4wheeling and Hunting
- 153
We use hard pipe and we tape each connection with foil tape and insulate everything but the return in a crawlspace, but we do tape all connections of the return and we also use duct sealer on the return. It works great with no duct leakage we have done a blower door test on a couple of jobs and have to shut it down pretty quick.
01-26-2005, 01:23 AM #3
- Jul 2003
- sacratomato
- 535
Anything you use needs to be UL-181 approved. A lot of people use mastic duct sealant, its a white water based compound you apply with a short bristle brush. There is a foil tape with a butyl rubber on one side. (foilgrip 1402)Carlisle makes both products.
http://www.hardcast.com/PRODUCTS/pr_detail.asp?pid=3
01-28-2005, 07:52 AM #4
Bldg. scientist recognize only duct sealing mastic. Tapes often don't stick to the oily metal or the fall off as the acrylic adhesive breaks down over time. Go to http://www.infiltec.com and read about duct sealing in the links section.
HTHKeep the fire inside the fireplace.
01-28-2005, 08:17 AM #5
we use United. http://www.mcgillairseal.com/textDocs/products.html
FILL OUT YOUR PROFILE!!
02-02-2005, 09:00 AM #6
- Nov 2004
- 5
I appreciate the responses. Sounds like foil tape ( the mastic type ) is acceptable. My contractor actually brushes mastic over the foil tape, though it got overlooked on my job. However, when I inquired about what was proper, he insisted on going back and putting mastic over all the foil taped joints. He says thats how they normally do it and his mechanic just dropped the ball.
02-02-2005, 09:46 AM #7
- Feb 2003
- Huntsville,AL
- 4,125
better jobs have insulated & sealed crawls -- read threads here & info @ BUILDINGSCIENCE.com -- then do not insulate ducts in crawl, nor floors above.
mastic sealing all seams, joints, cracks of ducts & plennums is good -- [ although my 1974 duct tape is excellent -- ALL still sticks tight to GI round!! ]
mastic over the foil tape is wasteful -- use a better foil tape, or just the mastic, IMHO.
BTW, I even put mastic at the metal edges of my panned return -- ok after 2+y.
[Edited by cem-bsee on 02-02-2005 at 09:48 AM]
