Thread: Carrier 5H86
    Apr 2009
    Carrier 5H86
    Had a request for a 5MH86 Carrier compressor. Carrier only shows a 5H series in the marine site. Is there a 5MH compressor in the first place. Or is someone pulling a fast one.
    Philly Area
    you are correct, the compressor would be a 5H series. The number 5Mh86 is an actual part number for the crankshaft if that is what they are looking to replace?
    Mar 2010
    Morgan Hill Ca.
    5MH86 is indeed a crank...
    You have to be careful with these because Carrier does not recommend the crank be machined to repair (not saying it cannot be done).
    On the standard stroke machines (5H80) it is standard operating procedure to cut them down to up to .020" under....
    GT
    If a day goes by and you have learned nothing, I hope you got a lot of sleep.
