Thread: Lennox a/c
    SE Michigan
    Lennox condensor model: hs16-511u-5p
    serial: 5187e14990
    Can anyone tell me how many tons of cooling this condensor is? Thank you in advance.
    4 ton single phase.
    Solid unit, heavy too.
    The only real issue with them is that the coil never looks dirty from outside. You have to take the top of of it to inspect and clean the coil.
    Nov 2001
    2 ton - 261 - 024
    21/2 ton - 311 - 030
    3 ton - 411 - 036
    31/2 ton - 461 - 042
    4 ton - 511 - 048
    5 ton - 651 - 060
    Which have you done ?
