Results 1 to 13 of 14
    B&G 1510 pump shaft sleeves
    How do you guys get the bronze shaft sleeve off of a BG 1510 series pump. A co-worker of mine that has done a few said everyone hes had to litterly gingerly etch and chissel off. I have one coming up and am looking for any advice. Thanks
    "It's just like it doesn't work. I mean it seems to be ok now, but it usually like never works"
    "Never an always and always a maybe"
    Jun 2010
    Colorado
    Torch.
    Heat it up good and hot and they come off with a pair of channel locks.
    Central NH
    I have had luck scoring the sleeve with a sawzall or hacksaw and splitting it with a chisel. Remember to use the supplied green locktite to secure the new sleeve.
    eastern north carolina
    b&g 1510 pump shaft sleeve
    lay the shaft on a hard surface like a vice hit, with a ball peen hamer along it`s lenght, rotate 180 degrees & do the same on the other side, do this a few times & it will come off.
    windy city
    heat wrench, or peen it.
    if it's not damaged, you could leave it.
    \m/
    original member of the racoon brotherhood
    Turn it up side down and heat with oxy/ace, it will fall off.
    Expect nothing, yet expect the unexpected.
    Press on Regardless, Endeavor to Persevere.
    just tap it off with a ball peen!
    true knowledge exists in knowing that you know nothing.
    Northwest GA
    I have used a bearing splitter and puller to get them off, but as others have said heat will usually do the trick.
    Superheat, that must be REALLY hot.
    May 2008
    Central Pennsylvania
    Little heat will break the retaining compound loose and it should slide right off. Mapp gas torch usually does the trick.
    Its been awhile but inverting it, heating it with MAPP and tapping with ball peen got that sucker off like nothing- worked great! Thanks. Also wondering if anyone knows what the difference between a 185140 (B&G part#) and a 185140LF (the LF could be the wrong lettering). Does the LF just mean it comes with the loctite? Both seem to be physically the same size but I found an old box with the sleeve in the box but no loctite and no letter designation at the end of the part# Just curoius.
    May 2011
    Chicago
    Link to Bulletin from ITT Site
    Try this link to the B&G old service bulletin for sleeve replacement. Hope this is helpful.
    http://www.bellgossett.com/literature/files/455.pdf
    Apr 2005
    where the beer flows like wine
    Quote Originally Posted by turbomaster View Post
    I used the same method, some accounts wont allow fires or require all kind of time wasters. I clamp the splitter at the end of the sleeve, bolt it and pull it while tapping it with a hammer, I thought I invented it .
    Jun 2010
    Miami
    I have used the bearing splitter too. Mostly on other brands before they started using loctite. Wear rings can be fun
