Results 1 to 13 of 14
    Jul 2001
    our local andover ddc guy had a pretty cool little meter, it ran on a 9v battery and could send out a 4-20ma or 0-10vdc output for testing actuators and stuff, they got them from a controls rep. never got the name, anyone know who makes this and how much $$$ i think it would be a nice accessory to my fluke meter
    Jul 2002
    NorthEast
    For the Johnson and Siemens actuators on the 10 VDC
    I use a 9 Volt battery
    works great
    Long as the battery ground is connected to the 24 V.A.C.
    neutral
    The Siemens tech gave me the tip
    Jul 2001
    yeah i do that to got the idea from the local belimo rep but this box can vary the signal like it was hooked up to the normal controller
    Apr 2004
    I PULLED A JOHNSON SERIES 350 CONTROL OUT OF A JUNK UNIT HOOKED IT UP TO A TRANSFORMER AND CORD, DOES 4-20 AND 0-10 VOLTS .PLACE A RESISTOR ACROSS SENSOR TERMINALS (1000 OHMS I BELIVE}HAS A LED GRAPH ON THE FRONT THAT TELLS YOU WHAT THE OUTPUT IS WORKS GREAT AND ISNT EXPENSIVE
    I think Wolfdog posted this link a few weeks ago.
    Handheld Portable Analog Signal Generator [/B][/QUOTE]
    May 2002
    Baton Rouge, Louisiana
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    Dec 2003
    45th Parallel
    Fluke 715, only way to go.
    Philadelphia
    Forget the Fluke and the Johnson M-9000. Buy a Kele ASG. Runs on 9 vdc battery or external power (comes with own converter). Generates 0 to 10 vdc or 0 to 20 mA outputs. Also has a nice little ramp output feature. Comes in own little pouch. Great, inexpensive, portable tool for testing motors like Belimo or Barber-Colman "beer" cans and the like. Oh, can also "source" mA signal from own power supply or be used in a "loop powered" circuit. Think it cost me like $130.00 plus shipping.
    Jul 2001
    i think the kele one is the same one, thanks
    Jan 2005
    Miami, Florida
    Dwyer Instruments also has a hand held unit. Sells for $179, Kele unit is $279.
    Jul 2003
    MA/V source
    I have had a ALTEK 134 since 1994. Its small and ISO certified and clibration.
    http://www.altekcalibrators.com/default.asp
    Aug 2000
    Under my tree
    I have the KELE one that cost about $130, great tool, saves alot of time when setting up actuators and such.
    To much work with too little time!!!!
    I have also used a JCI A350P for a long time (Way to think out of the box, bobbym).
    The only drawback is having to drag around a cord but it didn't cost me anything as it was also a takeout from a CW AHU.
