Results 1 to 4 of 4
Thread: napolen gds
11-24-2010, 07:05 PM #1
New Guest
- Nov 2010
- 2
napolen gds
went on a service call today. on a napolen free standing fireplace. i belive the unit is 3 years old. and since it was installed the fireplace periodicly would not turn on and then would not lite for a few hours. so far the fireplace has had a new termopile new switch and the remote was removed. when i was there the fireplace turned on with no problems. there is no spill switch on the fireplace since theres no b-vent just a liner, all wire look good and all electrical connection are tight.has anyone run into something like this?
11-24-2010, 10:08 PM #2
- May 2005
- Madison, WI
- 1,078
Could be a bad valve with a loose connection internally. When someone walks by a few hours later it might restore the connection allowing it to work.
You can tap on the valve with a wrench while the unit is running to see if it effects the readings at all.
11-25-2010, 05:50 AM #3
New Guest
- Nov 2010
- 2
The gas valve was changed on the last call.
11-25-2010, 12:30 PM #4
- Jul 2006
- Virginia
- 378
What are the TP readings?
Common sense is NOT common !!!
