Thread: napolen gds
    Nov 2010
    napolen gds
    went on a service call today. on a napolen free standing fireplace. i belive the unit is 3 years old. and since it was installed the fireplace periodicly would not turn on and then would not lite for a few hours. so far the fireplace has had a new termopile new switch and the remote was removed. when i was there the fireplace turned on with no problems. there is no spill switch on the fireplace since theres no b-vent just a liner, all wire look good and all electrical connection are tight.has anyone run into something like this?
    May 2005
    Madison, WI
    Could be a bad valve with a loose connection internally. When someone walks by a few hours later it might restore the connection allowing it to work.
    You can tap on the valve with a wrench while the unit is running to see if it effects the readings at all.
    Nov 2010
    The gas valve was changed on the last call.
    Virginia
    What are the TP readings?
    Common sense is NOT common !!!
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
