Results 1 to 7 of 7
    Jan 2005
    DOES ANYBODY OUT THERE KNOW OF A WATER COOLED CONDENSOR FOR RESIDENTIAL USE BESIDES FREUS IF SO PLEASE RESPOND
    Freus is evaporatively cooled, not water cooled. Are you looking for a self contained unit or just the condenser?
    Jan 2005
    I AM LOOKING FOR A HIGH EFF. CONDENSOR EITHER WATER COOLED OR EVAP CONDENSOR FOR A RESONABLE PRICE.
    A condensor is just the part where refrigerant changes state. Is that what you need? Water cooled condensers are easy to find. Check any refrigeration house.
    A condensing unit is the complete compressor, condensor, fan machine. Only think I know of that is evaporative is Freus. Most brands of geos make a split heat pump with water cooled setup. Don't know of straight cool that way.
    Jan 2005
    I AM LOOKING FOR A WATER COOLED OR EVAPORITAVE CONDENSOR THAT IS A COMPRESSOR BEARING UNIT FOR RESIDENTIAL USE THAT IS NOT FREUS OR GROUND SOURCE HEAT PUMP OR WITHOUT A COOLING TOWER.
    Oct 2005
    A late response, but Allied Thermal in Austin has similar technology. I'm looking at a proposal now.
    Dave
    Apr 2005
    NE PA
    You should look at ClimateMaster. It is officially a "ground source heat pump" but will operate with any reasonable water source.
    paul
