Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 77
  1. #40
    S.E. Pa
    Exclamation no DIY
    First of all, this is NOT a DIY site so no advice on modifications.
    Q-fire, that was brutal trying to read your posts. Can you please try using capital letters to start your sentences and break it up into a few paragraphs? TIA.
    You should not be modifying your stove in anyway, much less advocating it online. You will void the warranty and listing so if you have a problem, the mfr. will be excluded from responsibility.
    You are operating your stove outside the mfrs. instructions. I recommend you stop this practice and burn only according to mfr.s instructions.
    You should not be burning more than 50/50 corn/ pellet mix. The corn should be dry shelled corn that has been sifted or washed to remove loose dirt.
    As to your explosion theory: you must have the proper ratio of air to fuel to burn. If air is moving through the stove as designed, this cannot build a combustible vapor cloud. Check your stove's air intake, glass gaskets, exhaust path, combustion blower and venting for obstructions and verify proper airflow. Then allow the stove to operate as designed. If it does not function as designed, call a pro to service it.
    Hearthman
  2. #41
    Jan 2010
    newhall iowa
    my guess is that you are the pro. I am not wrong. quadrafires just arent that good. you ever notice that as products progress a lot of changes are made? quadrafire does r&d in the field. and when i bought my stove I was told i can run 100% corn by quadrafire themselves. so once again you are wrong. How can you help people by telling them to go and pay 50 bucks an hour to fix their stuff. it may not be a diy site but i am sure any help people can get is worth it. why would they go to this site why not call quadrafire themselvs. so as the super guru you think you are if you help people by telling them how to fix it then you are a hipocrat. so maybe your reign is over. and who cares about how i write or spell. that is just a cheap shot.
  3. #42
    Dec 2001
    Ocean Pines, MD
    No DIY
    Hearth has some good advice. And leans towards safety.
    His comments on typing weren't meant as a cheap shot, at least I didn't read it that way. It would help getting the gist of what you're trying to say. We all try and make these clearer.
    Keep it civil.
  4. #43
    Jan 2010
    Quote Originally Posted by bartogden View Post
    When was it professionally serviced last?
    serviced same day they put in a new board
  5. #44
    Jan 2010
    Re: Pellets needed in hopper to turn auger
    Thanks Hearthman, that makes sense. Trying to find this much info anywhere else is impossible. This is a great site.
  6. #45
    Eastern Shore, VA
    Long Time Success with QuadraFire Castile
    Been using our QFire Castile since 2002. Great Success. I read the manual early on, and glad I did. The comments about cleaning by kroneage were right on. I never thought of using the Castile for more then about a month or more without cleaning benhind the steel plates and the top heat exchange tubes. I've used 4 types of pellets, sometimes 30%corn, (had a residue in firepot with corn, so don't use them anymore). Some pellets work better then others, but all seemed to work.
    I feel the imoprtant point is keeping the stove clean. While doing some preseason cleaning this year, I found a bit of ash in my vacum sensor line. Cleaned that out.
    Listen to Hearthman though, I've found throughout these threads, you can get great advise from his posts.
    SmoSki
  7. #46
    Dec 2010
    I purchased a Quadra Fire pellet insert about three months ago. I had it installed and adjusted to where it kept my house like I wanted it, fire about three to four inches above the fire pot and convection blower on medium. About two days ago the blower started cutting off while the fire was still going and then coming back on. I called the dealer and he suggested replacing the heat sensor in the heat exchanger which I did. With the new sensor I continued to have the same problem. I again called the dealer and he said to increase the feed rate and run the blower on high. This fixed the problem of the blower cutting off while the fire was on. I would prefer to run the heater as I shad , been doing, medium fire and medium blower speed, any suggestions as to how I can do this without the blower cutting off.
  8. #47
    Jan 2011
    Cool Quadra Fire pellet stove
    I purchased a quadra fire santa fe stove 2 years ago- it had problems right from the start. Fumes coming back into the house- after 2 visits tech tells me that the exhaust pipe has been re designed and needs a stuffing added to pipe! that fixed it, but they they acted I like I was an idiot!! 2 months into the stove stove's use and this problem started with the fire box running out of control (sounds like a jet engine running and wakes up everyone) I've had the fire dept. to my house over this stove (it sets off my my fire alarm's heat sensor) The dealer uses his son in law with a separate business to handle service work (it makes the buck easier to pass) They have been back at least 6 times and changed the control box 3 times or more. After they leave it will work ok for 2-3 days and then the fire starts the roaring, they keep making adjustments.....only tying to drag out any possible warranty. They're coming again tomorrow again and unless they find something actually wrong that they haven't tried before, I'll be taking them to court- people shouldn't have to diagnose Quadra Fire's problems!
    I like the stove but I'm at wits end, after reading some of these post I realize That Quadra fire needs to resolve these issues for people at NO Charge and stop trying to pass the buck onto the end user. I have a quadra fire wood stove and love it, so perhaps they should stick to wood stoves.
  9. #48
    May 2002
    Quote Originally Posted by q-fire View Post
    ...you ever notice that as products progress a lot of changes are made? quadrafire does r&d in the field. and when i bought my stove I was told i can run 100% corn by quadrafire themselves. ...
    Well, you are right about Quadrafire doing R&D in the field. At least that's the result. Obviously their testing or hardware is not nearly good enough. Which is the plague of most of these units. To be fair there is no way corn and pellets are completely consistent.
    But, I don't doubt that QF errs on the side of cheap instead of quality and I don't doubt your local place with where you bought the product told you 100% corn is A-OK. That's because they are "professionals" (quotes needed).
    I have about 25 years in the HVAC business and if I didn't have that under my belt probably I would not have bought the QF Castile I own because there is virtually no way I get good service from authorized dealers in my area. QF seems to have shut off their customer support department years ago already. Actually, I'm lucky because one of the better guys posting here is located in my state. It probably only takes an hour travel time for him to get to my location.... so much for positives.
    So, no doubt hearthman is rather good also, but he needs to face the facts that this part of the industry he is involved with is largely substandard.
    Buyer-be-big-time-aware when considering buying a pellet stove.
  10. #49
    May 2005
    Madison, WI
    I did not see anywhere that you said what stove you have? The only stove Quad boasts will ignite and burn 100% corn is the Mt Vernon AE. I know this is true also, because in the showroom we burned an entire hopper of straight corn on and off through the course of a few days and it never had any problems. This was cleaned and dried corn specifically processed and bagged for burning in pellet stoves.
  11. #50
    Mar 2011
    Thank you all for showing me I am not crazy. I have had Two Quadra Fire Pellet Stoves. The first one lasted for around 10 years without problems, until the end. Since we had such good luck with this stove, I invested in another Quadra Fire pellet stove. I am having problems with this stove. It is not three years old yet, but we began having problems with it almost immediately.
    The biggest problem now is that it will not feed pellets correctly. The flame either burns too high, or else not enough pellets are fed to start the stove. The pot has overflowed with pellets on more than one occasion (such as this morning). I was horrified to see this when I went to check on the stove. I have had a technician come several times, and I am charged for a service call, but the stove has not been repaired. The Technician was there Wednesday of last week. He made it sound as though we were the ones responsible for the problems we are experiencing with the stove. In my experience, the ash has been white when there is normal burning. In the last three or four months, the entire stove has been black.
    This stove requires more maintenance than the first one did. We clean the pot, vaccum the the feed box, clean the plates, empty ashes and everything else we have been told to do. The stove does not provide much heat, the blower is weak and it appeared it was "wheezing". It will burn properly during the day for a period of time, when we are there to keep an eye on it. I am constantly adjusting the feed rate of pellets because either we get too big a flame or else not enough of one and the stove turns off. It will take awhile for the stove to start when it turns off. Even when there is a huge flame, there isn't much heat coming from the stove, which is frightening.
    What could it be? I printed some of the posts that I am going to take to the Technician and see if the problem can be repaired. I am so frustrated right now, I could cry. This stove is a huge investment, and I feel that if the Company knows there are problems with their stoves, they need to let us know. Does anyone have a clue?
  12. #51
    May 2005
    Madison, WI
    What model?
    Burning "black" is a dirty burn. This will usually be caused by lack of maintenance. The air flow path (intake or exhaust) is restricted somewhere. Usually when you experience and "over feed" situation it is also a maintenance issue. Its not that too much is being fed in, but the pellets are not burning fast enough due to a restricted air flow path.
    Quote Originally Posted by airforcvt View Post
  13. #52
    Nov 2011
    Overfiring 1200
    Not a QF tech, but have replaced many parts and do see the overfiring on occaision.
    I've read many of your posts and must make the assumption that the install is according to code/ QF instructions. Number one- has a clean air feed, minimum 2 1/2" pipe for combustion to the outside air. Number two, is thoroughly cleaned at least once a year, minimum daily cleaning.
    I have an older Contour, now called Santa Fe and a 1200.
    The 1200 while very reliable, will produce the scary "whole box" flame on mine only when it is dead cold outside.
    I've traced this back to a simple problem: the interval between cycling is not enough. This means that the thermostat is calling for heat without a MINIMUM of 5 minutes between cycles.
    Solution here is to have a thermostat with it's internal offset adjusted correctly OR an external timer that will not allow the heater to call for heat more frequently than 5 minute intervals.
    The 1200's firepot cannot rid itself of the glowing embers and ashes in less than 3-5 minutes of "rest" time.
    This is obvious to the eye. So, if it's like 40 degrees outside, normal cycling should be maybe every 15 minutes or more.
    If it's near zero outside, there will be a minimum interval between cycling, the ash will cumulatively build up and the next thing you know, the firepot is half full of ashes, it never fully burns down to the bottom. This is visible.
    At this point I can expect huge flareups.
    Have a look at what is remaining in the firepot to determine if this is the case. As soon as you hear the heater come on, look to see what is left in the firepot before it starts dumping in new pellets, it should be near empty.
    Try to make a mental or written note of the cycling (i.e., one minute, five minutes, ten minutes, etc.) Time the cycle between when the heater combustion fan stops and comes back on.
    If the bowl is empty and you overfire, look elsewhere. If it appears to already have residual ash, particularly glowing embers, then you're cycling too frequently.
    Tom
