Results 1 to 10 of 10
    Feb 2002
    I recently received a free copy of Comfort View V3.0 software (Hear that Trane Management, free) due to that fact we will be servicing a new building with that system in it. I loaded the software no problem in my laptop and went about my business. The next day I was at a Trane job and needed to access a PCM. Couldn’t do it, my comm. port was taken over by the Carrier software. I uninstalled the Carrier stuff and continued on my way. I am now back at the office and have reloaded the Comfort View. I am trying to find a way to release the comm. port manually and re-initializing it when I need to. Does anyone know if and how to do this?
    Thanks guys.
    scepter
    Oct 2002
    Depending on what OS you have...control panel, performance & maintenance, administrative tasks, services. Change all the services that have to do with Comfortview to manual. Then when you want to use Comfortview just start the GUI service & the rest will start by themselves. Then stop all those services to use other software or reboot.
    Dec 2001
    set up 2 hardware profiles and it will help to know what OS you are useing
    Allen
    raleigh,nc
    Ditto on what jhawk said. Go into my the CVIEW directory with windows explorer and find the startup program. It has a wrench for an icon. Send this to the desktop or somewhere where it is easy to get to. Open this startup program and change all of the options to manual startup. Before you start Comfortview each time, open this program and click GUI Services start. This will start everything in the list. Then run Comfortview normally. This will prevent Cview from reserving com ports.
    Feb 2002
    Thanks guys
    That worked fine.
    Oct 2007
    One more option is to set your connection back from 232 or 485 to database only or remote connection if using a telink or nam, it will also release the port.
    What file exactly do I need to open to configure manual startup of the comfortview modules. I have looked in my CVIEW folder but could not find and file with a wrench.
    Has anyone had a problem with the com1 port not initializing on startup. I can't pinpoint ComfortVIEW as the problem precisly (although it's the main suspect), but when I startup the computer my Com1 hardport does not initialize correctly anymore. I need to change the resources tab or uninstall-reinstall com port 1 to get it to work with any program. Very annoying
    Zandman
    Annapolis,MD
    I have seen a utility from carrier that starts and stops c-view, releasing the comm port driver. Carrier Rep said he would e-mail it to me.
    Mar 2010
    cview
    I use service tool 5 to work in cview It works thru usb and will not interfere with other managment programs
