Results 1 to 13 of 20
    Midwest
    In this formula b = 6
    a = (2 x 20^4) / b^6
    So the answer is 6.8587
    If I already knew that a = 6.8587, and b was the unknown, how would I solve that problem so that the answer to b didn't come out in exponential form. I mean, so that the answer would come out as "6" instead of something to the something power?
    If it did come out as something to the something power, how would I convert that to a regular number?
    SE Michigan
    Talking
    Holy cow...your asking me to remember my pre calculus days. When your trying to solve to that power things get tuff. Well, I will tell you right now Im not going to do it!
    Im glad thats over.
    Sep 2001
    East Stroudsburg, PA
    Mid-
    You are going to sprain your brain if you keep this up.
    midhvac,
    Do the basic algebra and up end up with:
    b=(2x20^4/a)all raised to the 1/6
    You need a scientific calculator to get what b is. That is, 46656.07 ^1/6
    plug in all the numbers and the answer is 6.
    Is this what you were asking?
    Apr 2002
    Dallas, TX
    Perhaps some number theory may be appropriate here.
    'a' in this example is equal to exactly 320,000 / 46,656 or approximately 6.85871056241426611796982167352538 (using Microsoft calculator )
    'a' is considered a 'rational' number because it can be wriiten as a fraction, i.e., x / y where x and y are integers.
    Ok, lets assume 'a' = 7, what is 'b'?
    b = (320,000 / 7)^(1/6)
    where 'b' is approximately 5.979643919487405903197485402773 (again using Microsoft calculator)
    In this case, 'b' is an irrational number. There is no fraction, x / y, that can define 'b' where x and y are integers. Think about it! No integer numbers whatsoever. Raising this expression to the 1/6th power causes this to occur.
    Mmmmm... so does this help?
    Midwest
    You guys rock! Thanks! I've got a scientific calculator and the 1/6 power works.
    Midwest
    Originally posted by condenseddave
    Mid-
    Nah, I put an elastic support around my head, just in case.
    Midwest
    Hey! Wait a minute! Why are we using 1/6? Is it because the answer to b is 6? So I have to know the answer before I can work the problem?
    Apr 2002
    Dallas, TX
    Mid-
    Let's put that elastic support to work...
    Using your calculator, solve the following:
    x^3 = x * x * x = -27
    or x = (-27)^(1/3)
    A little figuring will show that 'x' must equal -3, i.e., -3 * -3 * -3 = -27
    Why does the calculator fail to figure this out?
    Apr 2002
    Dallas, TX
    Nope. Using apropriate math:
    a = 320,000 / b^6
    b^6 = 320,000 / a
    (b^6)^(1/6) = (320,000 / a)^(1/6)
    b = (320,000 / a)^(1/6)
    Jonesboro, Arkansas
    Talking
    I think I am going into another field. I will never figure this stuff out!!!
    Cincinnati
    You big bunch of math nerds.
    Jan 2003
    SE Pa
    Yea , bet they got pocket protectors too>)
