Results 14 to 18 of 18
    May 2002
    Baton Rouge, Louisiana
    Originally posted by lonboy
    Let's see.... PID is an acronym for Perplexing, Intimidating, and Difficult. In most cases if you leave off the D it works pretty well.....
    Now that we have that cleared up, what do you want to drive from the CV output, what and where is your PV input, and how are you adusting the SP?
    -Lb
    No PID stands for Pretty Intense Destruction
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    May 2002
    -Lb
    -See tmk wouldn't it have been easier to read that little Honeywell manual instead of attempting the easy way out?
    Lonboy, Joey, etc... You guys are really coming through... Thanks!
    Jul 2002
    NorthEast
    4 to 20 ma is immune to electrical noise and
    long wire runs that cause voltage drops
    You can convert it to voltage
    the same way the fire detection systems with smoke heads do
    place a resistor accross the line and read the voltage
    Yes 10 Volts D.C is much easier to read
    4-20madc vs 0-10vdc
    I thought I would throw my 2 cents into this.
    The main reason to use 4-20 madc loops is that current is common in series. A current loop holds it's accuracy over long distances, where the voltage drops on long wire runs. This is why the chemical/oil/instrumentation business has been standardized on 4-20madc (and occasionally 10-50madc) loops for over 30 years.
    For those who want to trouble shoot in voltage, you can use a 250 ohm resistor in series with a 4-20madc loop and measure 1-5vdc across it to get scale readings. Most receiving instruments (devices that receive the 4-20madc signal) have shunts built into their electronics, so sometimes it is possible to measure at the terminals of the device and see a scaled voltage signal.
    FWIW
    tmk is offline Professional Member TMBM bad email address
    Hey Thanks alot fellas!! You've been very helpful.
