Results 1 to 13 of 20
    Nov 2010
    blower won't turn on new furnace
    So i we just got a new high efficiency goodman furnace. My husband installed it with help from a friend. It was working well most of the time, but sometimes it won't turn on. Well, I can hear it begin to heat up, but the blower doesn't kick on all of the time??? Since it is new and the thermostat has been replaced I'm wondering if there could be a problem with the electrical between the two?
    Help--I'm so cold!!!!!!!!
    Dec 2006
    Middle Tennessee
    the fan motor waits a minute or so to turn on
    Better talk to your husband or his friend!
    Northeast Ohio
    Something is not properly installed according to the manual. We are not allowed to give DIY advise because of site rules (see no DIY disclaimer). Either review install instructions or contact a professional company to go over the install and trouble shoot the problem
    DEM
    Massachusetts
    Quote Originally Posted by maroon View Post
    This is where the installing companies warranty kicks in. Call the installing company and have them fix the problem. If they can't fix it, call another company and when it's fixed, bill the original installer.
    Remeber, a real pro makes difficult jobs look easy. But it's not so easy anybody can do it. That's why we have careers. We don't practice accounting or medicine, the unskilled don't perform HVAC installs.
    Sep 2010
    NY
    Quote Originally Posted by Airmechanical View Post
    Where is the manual? What does it say?
    Sep 2006
    Montana
    It sounds like you need to call your husband for a service call. If he was skilled enough to install, he should be able to fix it. These DIY installs just crack me up. They think it's so easy, but when it goes south, lets ask the pros what to do to fix it! The best thing to do would be to call a PROFESSIONAL out to look at the install and try to repair it. Keep in mind, if your husband and his friend didn't install it properly, it may cost you some additional $$$ to make things right. Gooman should be so proud of themselves, selling equipment to anyone that has the money via the internet. What does that really say about their company?
    butler pa
    time to call a pro to sse what he did..errr-- whats wrong...
    and it would be wise not to ask if its a warranty call ( free )
    Jun 2010
    Flashing lights in unit may tell you what is wrong. Then read the manual.
    If you are cold and it is urgent call a pro before it gets really cold and they are to busy to come out.
    Sep 2006
    Montana
    Quote Originally Posted by cturman View Post
    That's good advice to call a pro, but don't you think if he was smart enough to install it, he should be smart enough to troubleshoot it too? Maybe this is why it's better to have a pro install it. There would actually be warranty on the furnace if there is a defective component and more than likely if it was installed less than a year ago there would be a labor warranty as well. The money they might have saved is going to be gone now if they have to call a pro AND have parts replaced.
    Oct 2010
    SW Michigan, near Battle Creek
    unlikely to be t'stat related if it ever works. if the furnace does not do its job the 'stat can't do the stat's job.
    Jul 2009
    King Ranch Texas
    does it kick on some of the time?
    Sic semper tyrannis
    ‚——’ฏฏ‘;====ฑ—- * * * * * *
    !‚–’ฏฏƒนถ
    I can think of a thermostat problem that would create this symptom if the thermostat isn't electronic, but I think saying more gets into DIY. Could be this, could be that...
