Results 14 to 17 of 17
    No, he didnt give a model number so I cant even verify if there is one or not. I'm just throwing out things to check rather than letting him be misled by the flame shutting off.
    Im sure a service tech has been there by now, and she will post the news shortly
    Originally posted by madmike
    Hey Kpheat....
    Unit must be grounded properly to have flame rectification if you need to clean every 4 months try a new sensor. They are not that costly and maybe you just have a weak or very sensitive one. Thats what I would do anyways.
    madmike
    I checked the ground (traced + took connections apart everything looks okay) and put a new flame sensor in and it works okay. We'll see in about 4 months.
    thanks
    Pat
    Just curious, but what would the failure mode be of a flame sensor that requires replacment? (outside of course dirty or broken).
    It is merely a peice of metal with a ceramic insulator, no magic there. If replacing it works, if it wasnt damaged, then it was a poor connection or placement.
    chicago suburbs
    the OP is over a month old. i hope he's straightened it out by now.
    FILL OUT YOUR PROFILE!!
