Results 1 to 13 of 15
Thread: TXV flow rate
    Nov 2010
    TXV flow rate
    Hello all, I am new to this site and was wondering if anyone could help me with a problem I am trying to answer. I am currently attending a technical school for HVACR and am filling out a academic excellence test. The question I cannot solve nor find in my text book is, as follows: "What is the flow rate of a TXV in a r410a system as compared to the flow rate of a TXV in a r22 system". The answer choices are: A-equal, B-40 to 70% higher, C-15% greater, D-15% less.
    Has anyone here perchance, ever came across this info? If so could you let me in on the solution. Thanks for your time everyone.
    Maximo
    Oct 2010
    Syracuse, NY
    I would think equal. 410 is higher pressure. Both work on the same principle, superheat since they use a TXV. I also am in school so i may be wrong.
    Nov 2010
    Thanks for your replies. I am leaning towards the answer of "equal" also since I don't remember being told that r410 absorbs heat more efficiently than 22, only that it is more "environmentally friendly". It does operate at higher pressure but the TXV and all other system components are designed for that. If the heat absorption capabilities are equal and the two systems are equal in tonnage then the flow rate should regulate superheat identically. My only question now is if I am correct in assuming the heat absorption characteristics to be the same between the two. Any insight would be greatly appreciated.
    Quote Originally Posted by Maximo3 View Post
    Maybe a bit of research on your part would benefit you.
    I'm sure the answer is close at hand, you just have to find it.
  6. Likes bobster liked this post
  7. #6
    Oct 2010
    SW Michigan, near Battle Creek
    410a is supposed to have higher volumetric heat. so it should take less of it to do the same job. so flow should be less. I think.
  8. #7
    Aug 2010
    Wichita Fall, Tx
    Don't you hate it when you ask a question, then get a question not a answer?
    I've also heard that no question is a dumb question, but thats not the case for some of the answers.
  9. #8
    Quote Originally Posted by WFL-TX View Post
    In my experience, simply giving a student or an apprentice the answers turns them into idiots that can't think for themselves.
    I very often answer questions like this with directed questions to help them think in the right direction.
    Nothing personal.
  10. #9
    Quote Originally Posted by fearlessfurnace View Post
    Yep. Lower volumetric flow.
  11. #10
    Max.
    The answer IS in your text books. You have to read them more then once. I know. They can be a bit boring sometimes(I'm still trying to finish my first one ).
    Often. It can help to write down in your own words what you read.
  12. #11
    Max,
    as you know? there are 12,000 btu's per hour or 288,000 btu's in 24 hours
    if you need 12k btu's? in your evaporator?
    you need to find how many btus per pound in r-22 and
    how many btu's per pound in r-410a
    this can be found on an enthalpy chart
    if you know the enthalpy and density of the refrigerant?
    you will then know which one needs more FLOW!
    the refrigerant with the MOST btu's per pound would require LESS refrigerant .
    by the way, here is a nice refrigerant piping web site.
    http://www.mcquayservice.com/mcquayb...011_120407.pdf
    you might like it?
    true knowledge exists in knowing that you know nothing.
  13. #12
    Nov 2010
    Thanks again all
    You guys were very helpful. I went ahead and asked my instructor about this question, and he also directed my attention to the enthalpy characteristics of the two refrigerants. Turns out the flow rate for r410a is less since it does absorb quite a bit more btu per volume. I realized it takes less of the r410 to absorb as much heat as the r22. I have to admit, i wouldn't have gone to the enthalpy chart so soon had I not asked for help, but hey , Im here to learn. You have all been quite helpful, thanks again.
  14. #13
    good job Max!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
