Thread: Question?
    Jan 2005
    Question
    Janitrol Model# A24-10C Serial#890500299
    My home is cooled and heated by this model above; recently I noticed the outside unit is not coming for heat. The unit inside is working. I know that a heat-pump unit under normal conditions operates with the outside unit pumping the ouside air through the lines and through the air handler inside. Therefore; I suspect the unit is only heating by the auxillary heating coils?
    My main question before I call for service is to determine whether this unit is indeed a heat pump?
    SC
    That's an air handler model #. It will work with straight air or a heat pump. Need to know the model # of the condensing unit to know if you have a heat pump or straight air.
    BTW, it's an old one.
    No reserve. No retreat. No regrets.
    For those who have fought for it, freedom has a sweetness the protected will never know.
    http://www.airwarvietnam.com/16thSOSGunners2.jpg
    Proud member of KA Club
    Jan 2005
    Smile HVAC ?
    Okay, I will get it tomorrow and post it.
    Thanks for replying!!
    Colorado flatland native
    How cold is it outside
    Walter Matthau
