Results 1 to 13 of 13
    Nov 2001
    east kansas
    It showed what was on it, then wouldn't read anything after that. Now it wont read any of it.
    Anyway to restore it?
    Beware of advice given by some guy on the Internet.
    NJ
    Do you have another computer to try reading the floppy on? (Maybe even the one that created it? )
    "Punctuation and capitalization is the difference between: Helping your Uncle, Jack, off a horse. And: helping your uncle jack off a horse"
    If Mexicans will do the jobs Americans won't do, will they secure our borders?
    lynn: when you start up your comp hold down the esc key or the del key to bring up the bios ;
    under the options menu make sure that the FDc floppy drive controller is still enabled
    if not enable it then f-10 - y -restart and when it restarts part of the sequence should be to find the floppy . you will notice the light come on then go off , as windows starts ....try that and ill check back
    South Dakota
    lynn:
    Just so happens that my daughter just ran into the same problem. She just completed a school assignment and saved it to a floppy. Now she can't get it to open. We have tried to open it on three different computers. No luck.
    She is taking the floppy to a local computer expert to see if he can do something.
    Norm
    Nov 2001
    east kansas
    Tried it on another computer and no luck.
    No problems with other disks.
    I don't know
    You can try scandisk in windows - yes, scandisk works on floppies!!
    Floppy Disks are not reliable and NEVER should be used as a primary means of data storage. If you must use them, make a backup copy on a CD or your hard disk.
    I only use them for system recovery/diagnostics - when other devices are not accessible or the hard disk needs reformatting.
    Cincinnati
    What's a floppy disc ??
    Urbandale IA. USA
    Sounds like you might have a virus.
    Scan the floppy for virus's, then try it again.
    UPDATE your virus software WEEKLY!
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    You may have a problem with whatever program you used to write or store the info. Try reloading that if nothing else works.
    Hey cockroach, don't bug me!
    Jul 2002
    Slacking off right now
    Lynn noodle around on the net like at cnet you will find data recovery programs to down load. Some of them are trial versions that will recover the data then you buy a key to release the data. some trial versions will recover data up to a certain file size free of charge and then you pay if your file is larger.
    I have used some with a great deal of sucess even on defective cdrs.
    Good luck
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    manitowoc wisconsin
    I bought a whole box of 50 & all were defective but 12.Look on the bright side,You could have just had a critical hard drive mechanical failure that shorted your power supply & took out your mother board too.The plus to that is I got to build myself a new machine @ 2.6 gig cpu.I am still working through a few bugs though have fun I know I will!
    Take your time & do it right!
    Nov 2001
    east kansas
    There is nothing on it that I'll miss or can't rebuild easily.
    Florida's space coast
    Maybe you can get some help here.
    http://www.helponthenet.com.
    On the main menu go to forums.
    Sort of like the hvac-talk of the computing world.
    Good luck.
    We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
