Results 1 to 13 of 18
    Dec 2008
    Need a cheap 40 ton at -5F Chiller
    Hello,
    Looking for a low temp Chiller of 40 ton at tevap: -5F.
    The cheaper the better.
    Any ideas?
    As an alternative I was considering a commercial chiller of 100 ton, but this would be ineffiecient.
    Thanks!
    cheap at -5? can drake do one for you at that temp? probably. I know rae-tsi can. is that -5 evap or leaving fluid temp?
    Dec 2008
    Quote Originally Posted by flange View Post
    tevap = -5 F. Who is drake?
    manufacturer of small process chillers, owner by united refrigeration i think, and located in pa. usually sold through reps or united.
    Dec 2008
    ok. I was thinking in making a Chiller from a Condensing Unit, but must be pointless,for economic reasons. Where I can find a surplus or used Chiller like this?
    Dec 2008
    Which type of Compressor do they use? Copeland, Carlyle, Bock...?
    Do those manufacturers produce quality chillers?
    Rae makes a nice product, custom designed for your application, there are others as well. When you get away from comfort cooling applications, it usually is a custom machine. What compressors do you want? they will use them.
    Dec 2008
    I am not sure which compressor to Choose. Nowadays most of them are screw type. I thought for low temperature reciprocating were the best.
    MEXICO
    so that you will serve the chiller? processo ice machine
    Dec 2008
    Quote Originally Posted by servicetrane View Post
    Sorry, but I don't understand
    Not in Iran
    yea., i would try drake., prob have a scroll compressor in there.,
    simple design and easy to install., some misc water valves., elec and ur done., as far as a c/o goes anyways,.
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Dec 2008
    scroll? On low temp?? I thought that they were only for med temp.
    Which is the best for low temp, reciprocating, scroll or screw? Let's say for a 50 hp compressor..
    In most cases, recips will be slightly more efficient than screw at low temp, but require more maintenance. Screws on the other hand get tossed in the trash when something bad happens. its a trade off.
