12-30-2004, 11:55 PM #1
- Apr 2003
- Somewhere in the Caribbean
- 221
This is totally unrelated to HVAC, but maybe someone can help.
I recall seeing a high security door lock, that had a bracing bar that was unlockable from the outside, but locked the door against the bracing bar which sat in a pocket in the floor.
I can find info on door braces made to be used only if you are inside the door, but not on the type that I seek.
Thanks in advance,
(cause this may be my last post(unregistered))
cctrol
12-30-2004, 11:59 PM #2
You will still be able to post. Just not in the PRO forum.
Every other forum you see now will still be available.Karst means cave. So, I search for caves.
12-31-2004, 12:31 AM #3
- Jan 2003
- San Jose, Ca
- 2,089
contact a good locksmith co. in you area.
LenOld snipes don't die they just loose their steam
