    Apr 2003
    Somewhere in the Caribbean
    This is totally unrelated to HVAC, but maybe someone can help.
    I recall seeing a high security door lock, that had a bracing bar that was unlockable from the outside, but locked the door against the bracing bar which sat in a pocket in the floor.
    I can find info on door braces made to be used only if you are inside the door, but not on the type that I seek.
    Thanks in advance,
    (cause this may be my last post(unregistered))
    cctrol
    Grottoes VA
    You will still be able to post. Just not in the PRO forum.
    Every other forum you see now will still be available.
    Jan 2003
    San Jose, Ca
    contact a good locksmith co. in you area.
    Len
    Old snipes don't die they just loose their steam
