Results 1 to 13 of 23
    Nov 2010
    Warehouse Heaters for Light Assembly Environment
    Hello,
    I have a customer who wants me to make his heaters a little bit more people friendly.
    He manages a 65,000 sq ft light assembly environment that was once a warehouse environment with heat designed for warehouse.
    There are 2 - 25' tall giant gas heaters along the eastern wall of the building with intake on the bottom and exhaust on the top about 15' apart from intake to exhaust.
    When the heat is turned the blower runs constantly and the gas heat comes on intermittently. There are about 125 people in this room and when those heaters come on it is very loud, windy, and breezy. Papers are flying off of desks and everyone is complaining. Is there any practical solution to making these mega heaters a bit more personnel friendly?
    Thanks for the help.
    Jim
    Oct 2010
    SW Michigan, near Battle Creek
    cant think of much. it would be like trying to make a frieght train sound like a chevy. move the desks of course.
    Nov 2010
    Thanks for the reply. Can't move the tables, they are 50 feet long.
    Delaware
    Is the supply coming out the bottom?
    Always here
    Nov 2010
    Quote Originally Posted by energy star View Post
    No sir, the intake is on the bottom and the exhaust is on the top.
    Hello,
    Jim
    Hampton Roads, Virginia
    Add some ductwork?
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    Oct 2010
    Quote Originally Posted by klrogers View Post
    Add some ductwork?
    yeah, if the equipment is legal for ductwork. maybe some cubical partitions to baffle the return if it is retun air blowing the papers off the desks?
    Delaware
    I have put those in. You may be able to add 8' of duct on the top supply. Also look into a good diffuser manufacture (Titus or Price) they will help. You need a louvered (movable) diffuser face.
    Always here
    Nov 2010
    Quote Originally Posted by fearlessfurnace View Post
    Actually it is the supply air that is blowing papers off of the tables.
    It is also noisy and breezy.
    Thank You,
    Jim
    Apr 2004
    Muskegon, Mi.
    Check out ductsox.com. Might give you some ideas.
    Pa
    Sounds like you have air rotation equipment. Not much you can do to change the unit. Check the diffusers that they are perpendicular to the floor and blowing out and not down. Also find out what the equipment is designed for. Air rotation equipment is designed to have 2-3 air rotations within an hour and if it is more than that you will feel drafts through out the building. Make sure you have the correct temp rise and check the fans, you might be able to slow them down a bit. I find most air rotation equipment I run across designed with a 60 rise. See if the unit can be staged in any way so you can always keep the burner on. Is it a 3:1 burner, or just on/off.
    These units usually have a prop fan so static pressure won't be that high.
    yeah, air rotation, most likely johnson marcraft units. typically these do not get ductowork and cannot really handle a buttload of external static. These are mostly used for manufacturing environments where noise isnt an issue. They are suposed to Throw the air out and have it cycle back into the bottom. A vfd may help if you slow down the air some, but you need to watch the temp rise when the burner is firing so you dont overheat it.
    Jan 2003
    Kansas City
    Like flange says, a vfd and some type of modulating discharge air control would allow you to reduce noise, but you would also be reducing heat output and it may not be enough to heat the space.
