Results 1 to 8 of 8
    Nov 2009
    karachi
    calculate cfm in rectangular duct
    Can anyone explain me I want to calculate the cfm in a rectangular duct. what is the procedures and what steps I should follow.
    traverse the duct with test holes
    link didn't work
    area of duct in inches divided by 144 equals square feet. find velocity in feet per minute and multiply to get cfm. or get the right tools.
    You need to take probably about 20 samples across the duct to finds the flow pressure. Static press-Total press=flow pressure. You can then calculate with your area.
    http://www.dwyer-inst.com.au/Product...troduction.cfm
    Central NH
    Quick, but not Cheap
    Flow Hood. Hold it over the opening and read the scale. Problem solved.
    Sep 2010
    NY
    Quote Originally Posted by hedtedjr View Post
    Flow hood is the best.... cover and read, cover and read. What was the old fashion way? traverse with a tip that would pick up velocity and somehow it would cancel static to get only velocity and then you get the average of the sum. A few more steps and you have CFM.
    I would like to try a flow hood against an anemometer or a u tube to see how close the readings would be.
    Where is the manual? What does it say?
    Nov 2010
    Nevada
    Spend a few bucks and hire a professional with a flow hood(that has been calibrated recently).
    SG
    Jul 2010
    Knoxville, TN
    A traverse is best and most accurate. But just to get a ball park, you can measure velocity in a couple of places across the duct, take the average, and multiply by the square footage of the duct. Hot wire anemometers are pretty cheap.
