Results 1 to 10 of 10
Thread: Plumbing in sky scrapers?
12-24-2004, 03:55 PM #1
So I'm layin in bed last night, wondering... the sewer lines in a tall building (say 10 stories or more), do they just dump straight down into the sewage pit/sewer system, or do they have traps to slow the poo down?
My other half thought I was nuts when I was laying there, half awake, laughing thinking of the increadible speed of the pooh flying down a little pipe.
So what's the vertic you plumbing guru's?
12-24-2004, 04:11 PM #2
Tallest building I ever was responsible for was 11 stories.
There was a booster pump and pressure tank on the 5th floor to get water up to the top and there were S-shaped traps every few floors to slow down the descent. There were also a couple of big tanks at various levels where the stuff coming down would fall into the top of the tank and then start moving again out a drain pipe on the side. These tanks had vent pipes that went out the wall to fresh air. I guess to stop the syphon effect of 50 gallons of waste moving at 80 mph.Ryan
Maintenance Guy
naysayer, skeptic, conspiracy theorist
12-24-2004, 04:17 PM #3
- Nov 2004
- 125
Potable water is pumped to the top floors storage where it flows by gravity. Sanitary is "staged" downward a few floors at a time (not sure the exact number).
12-24-2004, 06:18 PM #4
Thanks fella's! I knew there had to be some magic to this. But it still is entertaining thinking of the speeds it'd hit the bottom with no traps!
12-24-2004, 06:53 PM #5
I have been is some high rises were the Chiller water had a ton of pressure on it.
On a 20 or 40 story building the main line going from the air cooled rooftop to the chiller in the mechanical room basement, can be real scarry doing a wet Tap.If common sense is so common how come so few of us have it!
12-25-2004, 02:25 AM #6
At the plant we use control valves set at a certain amount of pressure, set to release easy, to slow the velosity of poop and stuff. The pumps in the sump will handle the out flow.
12-25-2004, 07:30 AM #7You just made coffee come out my nose, now I gotta clean my keyboard.Originally posted by amickracing
My other half thought I was nuts when I was laying there, half awake, laughing thinking of the increadible speed of the pooh flying down a little pipe.R2B4BTU
12-25-2004, 07:35 AM #8
yea like what was said about the syphon effect.....imagine the guy sitting on the top toilet....suck his a** down the drain
12-25-2004, 09:20 AM #9Originally posted by oroy54
I was in a Orange juice plant in Dade city Florida, they were using steam for reheat. I had to purchase valves for the pneumatic controls they were using, it went from 600PSI to 30 PSI, cost was 400 bucks a poop er....I mean pop.If common sense is so common how come so few of us have it!
12-25-2004, 09:48 AM #10
you figure it would be like a highway with entrance ramps as the floors dump out during a normal day into the risers they would slow each other down...no alternate murging allowed.
"when in doubt...jump it out" http://www.youtube.com/watch?v=aMy-sAHwS4E
