Results 1 to 13 of 20
    Hell Hole Swamp
    TXV bulb mounting
    I found a lot wrong with this system, but this was the most pic worthy
    Mounted with packing strap, Im assuming from the air handler box
    Indiana
    they could at least cut the ends a bit.
    Aug 2009
    Plano, Texas
    haha, I thought it was a shoe lace at first.
    Urbandale IA. USA
    Shouldn't that metal tape give ample heat transfer from the bulb to the suction line????
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    At least it's on the dang suction line! One of our techs found one (fortunately not our job) on the liquid line this summer. And a screwdriving wedging the contactor on since the LP switch shut it down due to a huge leak on the low side.............!
    Jul 2005
    Geez! Just wrap it with some solid strand 10 gauge copper wire and be done with it LoL!
    Aug 2010
    Memphis
    Wow, that's nice. Creativity at its best. A tech I work with found some bulbs not even mounted, just hanging in the unit. Been like that for several years. Was a new customer.
    yea, at least it is on the correct pipe
    Oct 2010
    AZ
    I prefer jb weld for all of my mounting and pipe joining applications.
    Fredericksburg,VA
    I guess the installer was out of thumb gum.
    May 2009
    Earth
    Just wondering, has an installer ever tried to solder one to the suction line? Then I can say I saw it all. But probably not.
    las vegas
    saw one earlier this summer that was installed with that type
    of super glue for copper pipe joints & wrapped with elec. tape.
    held in position good so just installed the strap they left on top of
    the furnace & insulated it.
    had another one that someone had soft soldered a piece of 3/4
    to the suction line & just used it as a well to slide the bulb in
    & had used thermal paste inside the well.
    Nov 2005
    Louisiana
    I saw a pic once...maybe on here , where a guy had actually soldered the bulb to the suctionline.
