Results 1 to 13 of 23
Thread: Smoker Help!
10-31-2010, 05:59 PM #1
Smoker Help!
Got a new bransfed smoker given to me , IT is the style that has the firebox on right and the upright smoker box, Having problems getting the heat up above 250 even with the flue and vent door open 100%, got it loaded with some 2/3 yr old hickory but it doesnt seem to wanna bake the chickens in thing, Need your help as there are alot of fellow tech's that cook.
How much to open the vent and the flue, is flue for smoke , and vent for heat? , ThanksIf you build it they will come,,,they built it and they went.
11-01-2010, 10:13 AM #2
11-01-2010, 12:07 PM #3
- Oct 2010
- Overland Park, KS
- 153
11-01-2010, 10:54 PM #4
YA I had a small pan of water in it, but apon more looking seemed that I didnt have enough burnable wood in it, I added a few pieces of wood and it caught up, closed the vent to about 2/3rds closed and was able to hold about 300 deg. with the top 100% open to not oversmoke the meat, Was wondering about the differance of the top and flue doors, is top for smoke flavor and bottom heat?
Also believe that I should use charcoal along with wood to keep the heat and add wood only for smoke? What y'all thinkIf you build it they will come,,,they built it and they went.
11-02-2010, 09:02 AM #5
How big is the fire box? Before I went propane I had a charcoal smoker. And yes, in that one you only added wood for the smoke. You could never get enough wood in the little space that was intended for charcoal, to do your cooking.
Did you try downloading the instructions for your smoker.
11-02-2010, 05:42 PM #6
- Feb 2007
- 156
How many pieces of wood do you have in there? do you have a bed of coals? is there a damper between firebox and cook chamber? is the draw 100% open?
Constantly choosing the lesser of two evils is still choosing evil.
Jerry Garcia
11-02-2010, 10:17 PM #7
re
Firebox is roughly 18 widex 24 long x 16 deep, it does not have a damper betewwn firebox , and I did have a bed of coals in the bottom, really nice if I say so, as far as amount in there, am going to have to seal the lid on the fb to keep leakage out, and going to mod a diverter to go from entry to middle of smoker box as to prevent heat from raising directly on the right side of the box, still wondering this " is the damper on the firebox for heat control, and stack damper to keep smoke in, IF I burn door on fire open it will get to hot so should I close the draft door to smother flame and also or not close the stack vent?"
11-04-2010, 07:17 PM #8
- Feb 2007
- 156
Always leave your stack vent open and adjust heat with your draw. And come on your a southern guy whose asking a bunch of yanks about smoking.....just busting your stones
Jerry Garcia
11-05-2010, 12:12 AM #9
- Aug 2008
- Nebraska
- 34
You always want your vent stack damper fully opened.
11-05-2010, 07:20 AM #10
LOL
Southern by location,,, but bred and born in MI, Thanks for the damper answers, Going to try again this weekend, Going to use kingsford as my heat source and hickory chunks "slowly" added for smoke, going to try a small butt, Wish me luck,
MAde some The other day , the dogs liked it for awhile, but then quit eating it, so I guess you could say my that was so bad my dog wouldn't even eat it.If you build it they will come,,,they built it and they went.
11-05-2010, 07:39 AM #11
Good Info
Forgot this earlier, A good source of wealth and info.
http://www.smoking-meat.com/If you build it they will come,,,they built it and they went.
11-05-2010, 06:02 PM #12
Guest
- Apr 2005
- where the beer flows like wine
- 2,871
250F is perfect for smoking above that is called grilling.
11-05-2010, 06:53 PM #13
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
220 F max for smoking,start earlier! lol
