    Jul 2010
    Cambridge, MA
    Insulating a flue liner
    I have to put an aluminum flue liner in my chimney. It will be ventilating a 50 gal gas fired hot water heater only. I'm wondering if there will be enough heat generated that condensation may be an issue during the colder months. I'm in MA.
    Thanks for your thoughts.
    Oct 2010
    SW Michigan, near Battle Creek
    if it is by the book you should be fine.
    Rapid City, SD
    Have someone tune the water heater (properly) with a combustion analyzer, then you'll be 100% sure all is well, liner or no liner, insulation or no insulation.
    Jul 2010
    Cambridge, MA
    Thanks. I'll make sure my plumber does a combustion test.
    Jul 2010
    Cambridge, MA
    Edited for double post
