Results 1 to 13 of 15
    North Jersey
    Pneumatic guys - Diverting and Reversing Relay ??s
    Took over a building with some pneumatic VAVs, and found a bunch of these 'Diverting Relays' and some 'Reversing Relays' as well.
    Not sure exactly what these do, or how they work...Did a web search, but didn't find much info.
    Anyone know what these are all about?
    Thanks.
    MJB
    I like turbos
    Jul 2000
    Dallas,Texas
    Names differ, even by brand.
    A diverting relay could be a pressure selector relay. 2 different input pressure sources, 1 output. The control will control either the higher signal or the lower signal depending on which control is installed.
    A reversing relay may have 1 input, 1 output, and main air. As the input presure changes the output pressure changes in direct opposite proportion.
    Give us the number off that control and somebody will ID for you.
    Milwaukee Wisconsin
    Also could be a biasing relay (like a pilot positioner). Robertshaw/ Siebe i think, need #s.
    North Jersey
    Quote Originally Posted by wolfdog View Post
    That sounds like you're on the right track. I believe this building used to have two different pressures depending on if it were heating or cooling. Found two separate regulators tied into the old abandoned TAC control system (The building has new McQuays with BACNet control now).
    I'm gathering that when the unit was set to 'heat' that it would switch to the lower pressure so that the VAVs would 'know' it was in the heating mode and to basically switch functions.
    I'll get the #s off the controllers...We've seen two different types...Small black ones with a KMC tag on it...and these larger tan ones. Some say 'reversing relay' others say 'diverting relay'....
    Would love to switch some of these out to DDC so I can get some control over the areas.
    I like turbos
    Jul 2000
    Dallas,Texas
    Sep 2006
    Alaska
    Diverting Relays
    Diverting relays were often used to accomplish a complex task. The example I remember best is a fire alarm interface to pneumatics. When an area had a fire alarm the vav's could be set to shut down or open all the way to ventilate an area.
    Reversing relays were usually used to allow one controller to operate devices with different actions.
    For example you have a reverse acting thermostat controlling a normally open VAV box with a reversing relay to reverse the signal to a normally open reheat valve.
    Law Of The Thermostat: He who has the thermostat wins!!!!!
    windy city
    Quote Originally Posted by turbo50mike View Post
    Thanks.
    MJB
    looks like a robertshaw. will need # to tell you what it is and how it works.
    \m/
    original member of the racoon brotherhood
    Cal
    Is that wireflex on the box inlet? I hope you like correcting duct issues as much as turbo's mike.
    Delta BC Canada
    Jul 2001
    Canada
    looks to be a R503-3 ROBERTSHAW diverting relay ( most werre made by KMC ) its SPDT non adjustable.
    Newer part was # R403-3 for Robertshaw and now TAC 2353-503
    http://www2.tac.com/data/internal/da.../F_24550_1.pdf
    Mar 2010
    single duct w/ reheats or double duct? large tan ones sound like kreuter static pres controls. whats the action of the stats?
    Jul 2001
    Canada
    Large TAN one as in his picture is the RS R503 diverting relay and not static pressure.
    Mar 2010
    your right c man that's a 503 didn't notice picture last night.
