Results 1 to 10 of 10
Thread: Thermostat
    Apr 2010
    Thermostat
    A friend has a system that has a thermostat for the a/c system and one for the oil fired boiler. Will one digital thermostat control both of the systems.
    Jun 2008
    Cincinnati, Ohio
    Yes, if a professional does the installation.
    Jun 2010
    Queens. NY
    yes they should. Doesnt the newer thermostats come with a Y1, Y2 and W1, W2? for heating and cooling?
    Apr 2004
    Muskegon, Mi.
    Depends.
    Apr 2004
    Bartlett, IL
    That's a 2 stage stat.
    City That Never Sleeps
    Seperate transformers for ac and heat?
    You can get a single tstat to run both just need more info.
    Apr 2010
    Here is more info, First off I am just want make sure who she calls to do the job says and does this the right way. There are two White Rodgers analog thermostats now. One for the A/c and one for the oil-fired boiler. I will check about the transformers.
    it will work, its how my home is done. consult a local pro so it gets wired correctly, otherwise things go poof!
    Quote Originally Posted by bradley40550 View Post
    If there are 2 tstats you most likely have 2 seperate control circuits hense 2 transformers.
    If there using 1 it must be one hell of a huge VA transformer to be powering up the ac and bolier.
    Do some reasearch and do it right the first time buddy.
    Oct 2010
    SW Michigan, near Battle Creek
    the hardest part might be physicaly getting the wires all to one spot. and 'stat location does matter. the final price might be a bit of a shock
